Hi guys,
My current setup is Internet - RT-N66U - Switch - Clients. I have a lot of IP cameras and have DDNS set up in RTN66U.
I recently got a ASA5505, which I used to connect to my company...The set up required is Internet - ASA - RTN66U - Switch clients. ASA has a home vlan set up, with 4 ports being part of this vlan. One of these ports is used to connect my RTN66U.
Everything works with this set up but one thing. DDNS is not working anymore on my RT-N66U, the router is complaining about getting a private IP (192.168.x.x) from ASA and that it will not work with that.
Can you please help with any advice on what needs to be changed by keeping the way all devices connect in place? If possible only make changes to Asus router.
Thanks!
Thanks!
