doc octopus
I found it by accident. I do not know if it works, if you try it at your own risk
www.asus.ru/ftp/NW_TO_TEST/RT-N66U_3.0.0.3_151.trx
Installed the .151
I do not use QOS s cant comment on that, everything else looks good.
CC
OK I think I see how to set the QOS to work now.
Test with Bandwidth monitor d/l 2 gb file wirelessly from server.
NO QOS:
d/l speed 165 mbps
With QOS: set at my intrernet speed 1.2 mb u/l 12 mb d/l
d/l speed 52 mbps
With QOS: SET SPEEDS AT 200 mb u/l 200 mb d/l
d/l speed 165 mbps
With QOS: SET SPEEDS AT 450 mb u/l 450 mb d/l
d/l speed 165 mbps
The trick is to set the QOS speeds NOT to your internet speed but the potential router transfer speed (In my case I can set to 450)
Bottom line it works with QOS enabled!
CC
NO QOS:
d/l speed 165 mbps
d/l speed 52 mbps
d/l speed 165 mbps
d/l speed 165 mbps
CC
Welcome To SNBForums
