Rt-n66u minidlna rescan
kiesa1231
Hello all maybe possible disable minidlna rescan after every router reboot?.If minidlna files saved to hdd ext3 partition maybe possible stop every rescan when router reboots?But need leave new files fast discovery.Thanks for answers.
There are two minidlna threads on the next page which should cover it. Best to eject the drive really and in summary you need to disable in the web ui and manual start it without the -R switch in the command.
My /jffs/script/services-start is
#!/bin/sh
sleep 10
/opt/etc/init.d/rc.unslung start
sleep 10
/usr/sbin/minidlna -f /mnt/sda1/minidlna/minidlna.conf
It is ok?
Seems ok I can't comment on the unslung, but looking at your minidlna config path.
It would be better to label the storage as it might not be mounted as sda1 each time. Preferably use a no spaces label like Media unfortunately that change will require a rescan and updated paths in minidlna.conf so choose something you aren't going to want to change in a hurry.
