Hi all, this is my first post here. I am glad to have found this forum as I definitely need help!
I am trying to use the user-created certificate and key in the openvpn hosted in rt-n66u. I copied/pasted the key and certificates into the link under "Content Modification ...". Then I loaded the client.ovpn into my phone, the test didn't go through.
If I use the rt-n66u generated set of certificates/key, no problem.
What might be wrong here? The set of user-supply certificates / key were used in a WRT54GL running dd-wrt. I don't know if there is any specific requirements at rt-n66u. Any thoughts?
Thanks.
Thanks.
