RT-N66U router with the -37 SDK5 build
edsyl
I saw this in the latest release thread, but cannot seem to find it?
Where does one find it?
I really don't understand your stance? The RT-N66U router with the -37 SDK5 build from RMerlin is the best router with regards to polish (gui), range and throughput I have ever used.
I think you're quoting me?
Either way; RMerlin pulled that version because of USB issues.
Look for the .38 version soon.
Not my stance - if you read my posts completely it's the best one I've ever used on my RT-N66U.
RMerlin's stance was to pull it (along with the .37 old usb version) because it wasn't stable enough for him to leave for public access.
However, since I don't use USB drives with my routers (as I've mentioned before) it is working great for me.
It was the best ever but got pulled? I really don't understand your stance?
USB disks weren't mounted at all on these routers which I pulled, so hardly best ever LOL
merlin, i stuck a USB thumbdrive into the router, just for fun, and it worked np. router didn't reboot, but things did reload themselves. didn't lose any connectivity in the process that i'm aware of, at least not for longer than the time it took me to walk back to the computer.
(n66r, 37_1-oldusb (for posterity))
Jan  7 12:54:27 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 4
Jan  7 12:54:27 kernel: usb 1-1.2: configuration #1 chosen from 1 choice
Jan  7 12:54:27 kernel: scsi1 : SCSI emulation for USB Mass Storage devices
Jan  7 12:54:29 kernel: scsi 1:0:0:0: Direct-Access     TEAM     USB Disk         0.00 PQ: 0 ANSI: 2
Jan  7 12:54:29 kernel: sd 1:0:0:0: [sdb] 15771720 512-byte hardware sectors (8075 MB)
Jan  7 12:54:29 kernel: sd 1:0:0:0: [sdb] Write Protect is off
Jan  7 12:54:29 kernel: sd 1:0:0:0: [sdb] Assuming drive cache: write through
Jan  7 12:54:29 kernel:  sdb: sdb1 sdb2
Jan  7 12:54:29 kernel: sd 1:0:0:0: [sdb] Attached SCSI removable disk
Jan  7 12:54:29 kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Jan  7 12:54:29 hotplug[6564]: USB vfat fs at /dev/sdb1 mounted on /tmp/mnt/RENEE_1
Jan  7 12:54:30 rc_service: hotplug 6564:notify_rc restart_nasapps
Jan  7 12:54:30 FTP Server: daemon is stoped
Jan  7 12:54:31 Samba Server: smb daemon is stoped
Jan  7 12:54:32 Samba Server: daemon is started
#####ROUTER RELOADED HOSTS, KNOWN ERRORS REMOVED
Jan  7 12:54:33 hotplug[6567]: USB /dev/sdb2(unknown) failed to mount at the first try!
Jan  7 12:54:33 nmbd[6606]: [2014/01/07 12:54:33, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Jan  7 12:54:33 nmbd[6606]:   Samba server NIAGARA is now a domain master browser for workgroup DROWZYNET on subnet UNICAST_SUBNET
Jan  7 12:54:33 kernel: ufsd: use builtin utf8
Jan  7 12:54:41 nmbd[6606]: [2014/01/07 12:54:41, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Jan  7 12:54:41 nmbd[6606]:   Samba server NIAGARA is now a domain master browser for workgroup DROWZYNET on subnet 192.168.87.1
Jan  7 12:54:56 nmbd[6606]: [2014/01/07 12:54:56, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
Jan  7 12:54:56 nmbd[6606]:   Samba name server NIAGARA is now a local master browser for workgroup DROWZYNET on subnet 192.168.87.1
and here is after pulling the drive. the topology changes at the bottom i think is related to me being a little rough pulling the drive out
Jan  7 13:02:08 kernel: usb 1-1.2: USB disconnect, address 4
Jan  7 13:02:09 hotplug[6661]: USB partition unmounted from /tmp/mnt/RENEE_1
Jan  7 13:02:09 rc_service: hotplug 6661:notify_rc restart_nasapps
Jan  7 13:02:09 FTP Server: daemon is stoped
Jan  7 13:02:09 Samba Server: smb daemon is stoped
Jan  7 13:02:09 rc_service: hotplug 6658:notify_rc restart_nasapps
Jan  7 13:02:09 rc_service: waitting "restart_nasapps" via hotplug ...
Jan  7 13:02:09 Samba Server: daemon is started
#####HOSTS RELOADED AGAIN, REMOVED KNOWN ERRORS
Jan  7 13:02:10 rc_service: hotplug 6664:notify_rc restart_nasapps
Jan  7 13:02:10 rc_service: waitting "restart_nasapps" via hotplug ...
Jan  7 13:02:10 FTP Server: daemon is stoped
Jan  7 13:02:11 Samba Server: smb daemon is stoped
Jan  7 13:02:11 Samba Server: daemon is started
Jan  7 13:02:12 FTP Server: daemon is stoped
Jan  7 13:02:13 Samba Server: smb daemon is stoped
Jan  7 13:02:13 Samba Server: daemon is started
Jan  7 13:02:14 nmbd[6712]: [2014/01/07 13:02:14, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Jan  7 13:02:14 nmbd[6712]:   Samba server NIAGARA is now a domain master browser for workgroup DROWZYNET on subnet UNICAST_SUBNET
Jan  7 13:02:22 nmbd[6712]: [2014/01/07 13:02:22, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Jan  7 13:02:22 nmbd[6712]:   Samba server NIAGARA is now a domain master browser for workgroup DROWZYNET on subnet 192.168.87.1
Jan  7 13:02:27 kernel: br0: neighbor 8000.98:fc:11:71:04:da lost on port 1(vlan1)
Jan  7 13:02:27 kernel: br0: topology change detected, propagating
Jan  7 13:02:31 kernel: br0: received tcn bpdu on port 1(vlan1)
Jan  7 13:02:31 kernel: br0: topology change detected, propagating
Jan  7 13:02:37 nmbd[6712]: [2014/01/07 13:02:37, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
Jan  7 13:02:37 nmbd[6712]:   Samba name server NIAGARA is now a local master browser for workgroup DROWZYNET on subnet 192.168.87.1
The oldusb version does take care of the USB disk mounting, however I encountered other stability issues during my tests, so rather than waste time providing support to a version known to already be hack'n'patched together, I preferred to pull them off.
