Hello All,
I am not really an rooter buff, just a casual user with a problem. With the stock Asus firmware I was unable to lower Tx power. I have changed to Merlin because I hoped that it'd be possible with that.
Reason I want to lower Tx power is not because I am afraid of EM radiation or anything. The reason is that I have several other access points around the house and need to control tx power in order to manage the overlap. With the standard setting my clients keep connected to the Asus when other (and faster) access points are closer. Lowering tx power is very helpful, and in fact necessary, to make sure that clients always connect to the closest access point.
Another reason is that I have found (with other access points) that lower power can make connections more stable and in some cases even faster. Don't ask me why.
I started with 380.65 which is the latest version of Merlin. Tx power adjustment does not seem to work.
I had read somewhere on the forum that version 376 works, and it does. I am currently on 376.49_2 and have set tx to 20%. Perfect. I may increase to perhaps 30% but certainly not more.
I have also tried 378.56_2. Does not work anymore.
I now have several questions and hope someone is able to answer them for me.
1) Why has this important setting been disabled? Is it possible that it can be re-enabled in future versions?
2) What is the newest version of the firmware that still has this feature enabled?
3) Is it still safe to use such an older version? Please note that I am an casual user and wouldn't have gone to Merlin for any features other than lowering the tx power. But I am concerned with possible security and stability issues.
regards,
Lex
regards,
Lex
