I'm having a interesting issue with my router. So I am using the latest version of RMerlin's firmware 374.43 .. I had this issue on the previous version which was 374.39, but it seems like since I have upgraded it has got worse. Each time I flashed firmware, I reset to factory defaults and left modem unplugged for 10 minutes.
A overview of whats happening.. The Wifi will be working fine for a few hours with good speed, range and no hiccups, but then all of a sudden all device lose connection to the 2.4GHz network. It still broadcasts and I can see signal strength on my device and Wifi analyzer, but my phone for example wont connect. I have tried to forget connection and re connect but it doesn't connect still. To solve the issue, I just reboot the router and all is well again for a few hours.
A few other settings.. In the past I always used channel 1 because other routers around me do not. I changed to channel 6 yesterday to test and it seems like it got worse. I have the TX power set to 100, 20Mhz only, and b/g protection on.
Please help! Let me know if you need any other info, I would be glad to provide it.
