RT-N66U_380.62
solidmind
It seems like the page LAN->DHCP Server keeps loading. After a while the script logs out the admin user.
I try to change some settings in DHCP but the script logs out before completing the setting changes.
It looks like ajax_uploadicon.asp contains a script that keeps loading data or is in an infinite loop.
Any solution on this?
Thanks.
A few suggestions:
  1. Describe what you tried to setup in the DHCP part.
  2. Revert to factory defaults and start again.
  3. Upgrade to the latest Merlin firmware version.
Hi Woutery,
In the DHCP part I only added some devices to the static list.
Thank you for the tip to revert to factory. I saved settings to config, revert to factory, upload config, and now it is working like it should. No more logouts on DHCP page. Perfect.
Thanks.
