I have an RT68U and I installed the latest Merlin release on it, hoping to stabilize the Dual WAN feature. Unfortunately it is as unstable as the stock ASUS code. Primary WAN drops for no apparent reason. I understand WANs go down, that is why I have two. I know my Comcast cable connection does not go down every hour or so.
It seems there is a lot of chatter in the log for a router that should just sit there serving traffic. No new connections being added, no new hosts. Why all this DHCP checking on the WAN connection?
<I had pasted a log section but this forum only allows short posts so I removed it>
There are some (undocumented) options for Dual WAN. What are the recommended settings? If those don't exist, should I use Watchdog? This was required on my Cisco RV42 which would only fail over on complete link failure (very rare) but not when the link stayed up but the WAN connection was bad (not so rare). I have watchdog enabled on the RT68.
I could surrender and go back to using my RV42 but I'd give up WAN speed in that case. My cable modem has GbE and over wifi I've measured 110Mb/s over speedtest.net. Not possible using the RV42.
Any tips appreciated. Thanks!
Sander
Sander
