I was really hoping to retire my Cisco RV042 and use my RT68U to do WAN failover. Nope. Stunningly unreliable in stock form and really the same using Merlin. Frankly I doubt this was ever properly tested or this feature would have been removed from both firmware trees. WAN links keep dropping when they are stable when used in single WAN config.
So I have put my RV042 between DSL and cable modems and the 68U. The link is stable now but because the RV042 is only 10/100 capable my cable speed dropped from 120 Mb/s to about 60 Mb/s. Perhaps the '42 is maxing out before the 100 Mb/s link maxes out, who knows.
I have some syslogs I can post that show how the dual WAN config behaved when I ran it for about 4 hours but it may contain information I shouldn't post publicly. Let me know which lines I should remove, if any, before posting. Actually, let me know first if there is any hope that this may get fixed or if I'm out of luck and need to call Comcast to downgrade my internet to a lower tier because I can't use the current 100+ speed.
I'll add I use Dual WAN in failover mode because my backup is a 3.5 Mb/s DSL/U-verse line. Load balancing makes little sense in this case.
Merlin 374.43_2
Thanks,
Sander
Merlin 374.43_2
Thanks,
Sander
