Can anyone give me advice on settings between these two devices?
I've tried everything I can think of and its just very slow in one direction.
I have my EAN66 running in ethernet adapter mode, plugged into my ps3's lan port, and it's running showtime for my media box. When I FTP into it, if I'm sending a file to it im lucky to get 3.5Mb/s.. moreso around 2-3Mb/s.
But if I pull a file from it, back to my machine, it gets around 12Mb/s. Fair enough it is working from a USB drive that is hanging off the ps3, and that does slow it down slightly, but not that much! - Have tested to internal drive as well and it suffers the same issue, but is a little faster...
Why is it so much slower to upload compared to download? It is the ONLY device on 5Ghz band, there are no 5Ghz networks around me, no interference at all..
It's quite annoying because I send to my 'media box' more than i need to download from it...
I am running Merlins latest version as of this post that is 3.0.0.4.374.39
5Ghz band has its own unique SSID with the following settings:
Hide SSID - No
Wireless mode - Auto (optimized for xbox is NOT checked)
Channel Bandwidth - 20/40/80 Mhz
Control Channel - Auto
Extension Channel - Auto
Auth Method - WPA2-Personal
WPA Encryption - AES
Key Rotation Interval - 3600
Enable radio - YES (obviously)
Scheduler - No
AP Isolated - No
Roaming Assistant - Disable
Enable IGMP Snooping - Disable
Multicast Rate - Auto
Preamble type - Auto
AMPDU RTS - Enable
RTS Threshold - 2347
DTIM Interval - 3
Beacon Inteval - 100
Enable TX Bursting - Enable
Enable WMM APSD - Enable
Optimize AMPDU aggregation - Disable
Optimize ack suppression - Disable
Explicit Beamforming - Enable
Regulation mode - OFF
Tx Power adjustment - 120mW (was running this at 200mW - seems to make little difference, except to range).
The EAN66 has very little configuration. Just set as ethernet mode, and it picks the rest up from the router... matches the channel used etc.
I have tried manually setting bandwidth, channels, changed power adjustment, made sure nothing else is around to interfere with the devices etc and nothing seems to make a difference!!!
Slow sending from RTAC66U to EAN66... but fast going from EAN66 to RTAC66U !!!
Any idea's please???? Ripping whats left of my hair out
edit: i see there is now a 3.0.0.4.374.40 firmware... so I'll read the notes and put that on an see if it helps - but still keen to hear about anyone elses idea's or experiences with same or similar setups
Hide SSID - No
Scheduler - No
AP Isolated - No
AMPDU RTS - Enable
DTIM Interval - 3
