Run script on USB Ethernet gadget plugged in
yukky
Hello,
Hardware: RT-N66U
Firmware: 380.62
I am trying to connect a Raspberry Pi Zero device as an Ethernet gadget via the USB port on the router. Everything works, except I need to manually put the usb0 interface up and add it to the br0 bridge. How can I automate this?
When plugging in the device:
usb 1-1.2: new high speed USB device using ehci_hcd and address 5
hub 1-1:1.0: unable to enumerate USB device on port 2
usb 1-1.2: new high speed USB device using ehci_hcd and address 6
usb 1-1.2: new high speed USB device using ehci_hcd and address 7
usb 1-1.2: configuration #1 chosen from 2 choices
usb0: register 'cdc_ether' at usb-0000:00:04.1-1.2, CDC Ethernet Device, 06:b2:42:13:0d:a2
commands I would like to run upon device registered
ifconfig usb0 up
brctl addif br0 usb0
The commands need to be re-run everytime the USB gadget is plugged in/out.
What would be the best way to automate this, or is there a way to have this configuration persist?
I'm also seeing this, so I'm not sure if I should be in promiscuous mode or not...
device usb0 entered promiscuous mode
br0: port 5(usb0) entering listening state
br0: port 5(usb0) entering learning state
br0: topology change detected, propagating
br0: port 5(usb0) entering forwarding state
I think promiscuous mode is normal. See this:
dmesg|grep prom
Right, everything is in promiscuous mode.
Any clue about running a script on USB connect? Perhaps via hotplug2?
I've got everything working now!
I didn't have any luck with script_usbhotplug in nvram
/jffs/scripts/init-start
#!/bin/sh
# Replace hotplug2 rules with our own, and restart hotplug2
ln -sf /jffs/hotplug2.rules /etc/hotplug2.rules
killall hotplug2
line added for SUBSYSTEM == net
DEVPATH is set, ACTION == add {
makedev /dev/%DEVICENAME% 0644
SUBSYSTEM ~~ ^(usb|tty|block|scsi_generic)$, ACTION == remove {
remove /dev/%DEVICENAME%
MODALIAS is set, ACTION == add {
exec /sbin/modprobe -q %MODALIAS% ;
SUBSYSTEM == usb, DEVICENAME ~~ ^([1-3]-[1-3][:.0-9]*+)$, ACTION ~~ ^(add|remove)$ {
exec /sbin/asus_usb_interface %DEVICENAME% %ACTION% ;
SUBSYSTEM == usb, DEVICENAME ~~ ^(lp[0-9]+)$, ACTION ~~ ^(add|remove)$ {
exec /sbin/asus_lp %DEVICENAME% %ACTION% ;
SUBSYSTEM == tty, DEVICENAME ~~ ^(ttyUSB[0-9]+)$, ACTION ~~ ^(add|remove)$ {
exec /sbin/asus_tty %DEVICENAME% %ACTION% ;
SUBSYSTEM == tty, DEVICENAME ~~ ^(ttyACM[0-9]+)$, ACTION ~~ ^(add|remove)$ {
DEVICENAME ~~ ^(sg[0-9]+)$, ACTION == add {
exec /sbin/asus_sg %DEVICENAME% %ACTION% ;
SUBSYSTEM == block, DEVICENAME ~~ ^(sr[0-9]+)$, ACTION == add {
exec /sbin/asus_sr %DEVICENAME% %ACTION% ;
SUBSYSTEM == block, DEVICENAME ~~ ^(sd[a-z][0-9]*+)$, ACTION ~~ ^(add|remove)$ {
exec /sbin/asus_sd %DEVICENAME% %ACTION% ;
SUBSYSTEM == block, DEVICENAME ~~ ^(mmcblk[0-9]p[0-9]*+)$, ACTION ~~ ^(add|remove)$ {
exec /sbin/asus_mmc %DEVICENAME% %ACTION% ;
SUBSYSTEM == usb, DEVICENAME == usbbcm, ACTION ~~ ^(add|remove)$ {
exec /sbin/asus_usbbcm %DEVICENAME% %ACTION% ;
SUBSYSTEM == net, ACTION is set {
exec /sbin/hotplug %SUBSYSTEM% ;
exec /jffs/scripts/script_hotplug.sh ;
SUBSYSTEM == misc, DEVICENAME ~~ ^(tun|tap)$, DEVPATH is set, ACTION == add {
exec mkdir -p -m 0777 /dev/net ;
symlink /dev/%DEVICENAME% /dev/net/%DEVICENAME%
#!/bin/sh
echo $(date)" Action: "$ACTION" Product: "$PRODUCT" Interface: "$INTERFACE >> /tmp/hotplug.log
if [ "${INTERFACE}" = "usb0" ]; then
  if [ "${ACTION}" = "add" ]; then
    ifconfig usb0 up
  fi
fi
Thanks for the help all!
Is there a unique ID for the USB device? How would I recognize a specific USB device?
You can check the line that gets added to /tmp/hotplug.log, however in my case with the USB ethernet gadget, I only get:
Fri Sep 30 19:44:12 DST 2016 Action: add Product:  Interface: usb0
Fri Sep 30 19:53:33 DST 2016 Action: remove Product:  Interface: usb0
$PRODUCT is unfortunately blank for me.
The OpenWrt Hotplug wiki page says you can try to grab this information:
logger -t DEBUG "hotplug usb: action='$ACTION' devicename='$DEVICENAME' devname='$DEVNAME' devpath='$DEVPATH' product='$PRODUCT' type='$TYPE' interface='$INTERFACE'"
