Running a script after unexpected reboot.
fryedchikin
Hi Everyone, This is a question for all you scripting experts.
I am running 378.53 on an RT-68P and would like to know how to trigger a script after an unexpected reboot occurs.
I currently have a wan-start script to perform some actions but obviously it runs every time the router reboots. I need to move these actions to a separate script which will only execute after an unexpected reboot or loss of WAN connectivity (such as a power outage or ISP outage). If the router is intentionally rebooted manually via the UI or via a cron job I would not want the script to run.
Any help would be greatly appreciated.
Thanks!
Anyone have any ideas ?. Is there really no way to detect an unexpected WAN outage ?.
Even Windows is smart enough to know when it wasn't shut down properly lol :)
I dunno
You can identify if wan-start was invoked as part of a normal boot of the router or because of an unexpected WAN restart request..
in init-start
#!/bin/sh
HARDWARE_MODEL=$(nvram get productid)
MYROUTER=$(nvram get computer_name)
BUILDNO=$(nvram get buildno)
/usr/bin/logger -s -t "($(basename $0))" $$ "Martineau $MYROUTER BOOT in progress... [$@]"
# NOTE: Can't use Flash drive /tmp/mnt/$MYROUTER/ 'cos it hasn't been mounted yet :-(
# 'flock' is probably a better solution rather than the 'echo'
echo $$"-"`date` > /tmp/BOOTINPROGRESS # PID will allow other scripts to identify locker
# Should be sufficient to cover BOOT process?
sleep 150
# Move Syslog to USB Flash drive
/jffs/scripts/syslog-move.sh
<snip>
rm /tmp/BOOTINPROGRESS # Clear semaphore
# Create additional sempahore to indicate unexpected BOOT (see services-stop)
echo $$"-"`date` > /tmp/DIRTYBOOT
then in wan-start
# Unexpected WAN restart?  (see services-stop)
if [ -e /tmp/DIRTYBOOT  ]; then
  # Perform 'abnormal' non-BOOT wan-start actions
fi
# True REBOOT in progress? (see init-start)
if [ -e /tmp/BOOTINPROGRESS  ]; then
  BOOTINPROGRESS="YES"
  # Perform normal BOOT actions
fi
...and in services-stop
# Clear semaphore to indicate this is a controlled SHUTDOWN/REBOOT either by the GUI or clear semaphore in CRON script
rm /tmp/DIRTYBOOT
NOTE: If init-start either prematurely removes the semaphore '/tmp/BOOTINPROGRESS' or prematurely creates the semaphore '/tmp/DIRTYBOOT' then wan-start actions may be consequently inappropriate.
