running process as a service
macbean
I have a RT-AC68U running asuswrt-merlin 380.59 on which i've also installed entware-ng.
One of the items I am using is ipcad, but I cannot figure out how to run it as a service or at the least have it start automatically after a reboot. I've tried adding it to the services-start file but after any reboot, i still have to manually start ipcad.
i've looked around and can't really find anything other than 'add it to services-start'
Have you tried: "insmod ipcad" without quotas in services-start? Dont forget shebang (#!/bin/sh) on top.
#!/bin/sh
insmod ipcad
I'm not familar with insmod so no I hadn't tried that. But if the command line to start ipcad requires the config file location, will that work by itself?
If you have in eg /jffs you have to set full path to it.
#!/bin/sh
insmod /jffs/configs/ipcad
insmod is only for loading kernel modules.
#!/bin/sh
/jffs/configs/ipcad start
Sorry some brain fart...........
