Hi there everyone! This is my first post. Hope some could help me with these!
I have a AC68U with latest Asus Merlin Firmware. I plugged in a 1TB usb3 disk in the usb 3 port and activate samba share. While connecting with anonymous login i have no problema accessing the folders within WORKGROUP. If i disable the anonymous acess and set any user (admin per exemple) with acess RW to all folders i get the following error when trying to open the share:
Open Folder //appears in the title of the window//
\\COMPUTER-NAME is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions.
The stub received bad data.
Cannot access from wired PC directly to the router (using same WORKGROUP) with Windows 10 Home 64 Bits.
Any ideas?
Thanks!
Any ideas?
Thanks!
