cxadslfkj9w
I'm running two AC88U's (both with Merlin 384.16) in a router<>node mesh configuration (wired back-haul).
I see the node in my network neighborhood and on the AIMesh node I see samba is running.
I don't have Samba enabled on the router, and do not know of a way to disable Samba on the node. Perhaps this is left over from when the second AC88 was added as a node (maybe I enabled samba on the second AC88 before it was a node)?
Is there a way to disable Samba on the node, or should I reset the node to defaults and re-add it to the network?
/usr/sbin/smbd -D -s /etc/smb.conf
