I've installed sane on my RT-AC66U running merlin firmware build 3.0.0.4.374.33.
It appears to be working, generally:
I looked in /tmp/mnt/entware/entware/lib/sane/libsane at all the libsane-*.so.* files, which I take it are the backends for various printers?
Is there a backend or something else I need to install to get scanimage to recognize the Brother device?
Or am I just out of luck?
# scanimage -L
device `pixma:MX870_192.168.1.37' is a CANON Canon PIXMA MX870 multi-function peripheral
# sane-find-scanner
# sane-find-scanner will now attempt to detect your scanner. If the result is different from what you expected, first make sure your scanner is powered up and properly connected to your computer.
# No SCSI scanners found... (as expected)
found USB scanner (vendor=0x04f9, product=0x01e9) at libusb:001:003
# Your USB scanner was (probably) detected. It may or may not be supported by SANE. Try scanimage -L and read the backend's manpage.
That USB scanner would be the Brother DCP-7040 plugged into the USB on my router, which is actually the scanner that I want to share.device `pixma:MX870_192.168.1.37' is a CANON Canon PIXMA MX870 multi-function peripheral
# sane-find-scanner
