Schedule to disable a port on my router.
Russell Bantin
l want to enable/disable a port on the router. For example ethernet eth2 is connected to another router supplying all my children's devices. They have figured a fake MAC workaround to get by my parental limits. So, I want to switch on 7:00am, switch off 7:00pm. How can l enable/disable ehternet eth2 on a schedule?
You can't disable LAN ports. You'll have to try and disable internet access on the second router.
