Scheduled reboot problem
apotts
Apologies in advance for any newbieness...
RT-AC68U
350.58
All working fine, one openVPN server running, handful of clients. Reboot button in GUI does a good reboot.
After a scheduled reboot, the GUI is unobtainable, the wireless SSIDs appear on devices but the devices can't connect, no internet connectivity for wired devices, however all the blue lights on the 68U look and flash like normal. A power cycle fixes this.
Is this known behaviour, or is it just me?
TIA.
@apotts, did you solve your problem? I'm having the same on my RT-AC68U, no matter the FW version (as soon as I bought it I flashed 380.61, and now I'm on 380.62_1). Same thing after a factory restore - after a scheduled reboot wireless devices can no longer connect, and a power cycle fixes it.
PS: I'm not using entware/optware nor user scripts, only logging to a usb key - as soon as I have a second I will try and schedule a reboot without the key attached.
The same problem with RT-AC68U 380.65. Had to turn the scheduled reboot off.
