Scheduled Restarts
Cliff McLoughlin
Hi
Is there any way to schedule my AC68U to restart once a week or once a day? If it involves a script could you please give me a 'dummy's guide' to setting it up?
Cliff
cat << EOF > /jffs/scripts/services-start
#!/bin/sh
/usr/sbin/cru a ScheduledReboot "0 6 * * 4 reboot"
EOF
With putty the above will reboot the router ever Thursday at 6am
ls -l /jffs/scripts/services-start
cat /jffs/scripts/services-start
this will check if code saved and used on boot
http://www.openjs.com/scripts/jslibrary/demos/crontab.php
if you want a diffrent day/time the above will help you
Thanks for the help. Unfortunately I seem to be missing something as after over 5 days my router has not restarted.
As you can see from the screen capture (Asus Admin) I have enabled jffs scripts in Admin, System
As there were 2 very similar but slightly different options suggested I tried each individually and then both together. So currently in my /jffs/scripts folder I have init-start
and the same in services-start.
I also ran chmod a+rx /jffs/scripts/* to make the scripts executable and ls -l shows both files as having permissions -rwxrwxrwx.
What am I missing?
Cliff
run a "cru l" to make sure the job was added to cron.
Also after adding the to init-start, did you reboot for the cron entry to be added?
Thanks Calisro
I tried that and it isn't listed. So it doesn't appear to be getting added (and yes I did reboot)
I just now tried typing
/usr/bin/cru a scheduled_reboot "0 3 * * * reboot"
into putty and then cru l it shows up.
It looks like the scripts aren't working correctly.
I just realised that both scripts have the same cru name and changed one and rebooted. Now cru l is listing both. I'll see if the router restarts tonight
Thanks for the help
#!/bin/sh
EOF
In putty if you typed that line for line it will reboot ever thursday at 6am, Only time i seen this not work is IF it was not typed right or if the router was deleting JFFS on boot, Which was an old bug that has been long fixed.
IF you have done my way and the way that was link before mine it might be conflicting best to delete the jobs or format the JFFS and pick one to use
I been manual imputing the above code every-time I upgrade the FW and so far it always worked
Honestly if you need to have the router reboot every day or what ever maybe its time to consider another router that actually works for you. :rolleyes:
This old thread comes up in current Google searches for this issue, so I thought I'd comment.
The current version of the Asuswrt-Merlin firmware now has automated restarts / reboots built into the GUI. For some reason it took my eyes a long time to find it so I'll point it out. This feature is under the Advanced Settings / Administration / System tab. It is in the Miscellaneous section. See screen capture:
As to why reboots would be needed... I don't think I actually need them right now. But why not?
In another setting, I'm stuck with a worthless Comcast router that has to be rebooted daily to remain stable, so I've just made turning this setting on a habit...
Also - in this setting - I'm experimenting with whether or not reboots help or hinder connectivity and speed of my connection to a VPN server. Let's me connect each morning to the VPN network server that they currently think has the lowest load and is working best for my area. Looking to see if this is a good idea, or if I am better off keeping and holding indefinitely a VPN server that's proven. Of course, this is a new topic for another thread... but part of why I'm currently rebooting.
