I seem to be having a problem with the scheduling of parental controls.
I want the device to be active all day Saturday. However, as soon as I set it up and hit OK, and then return to the scheduling screen, the Saturday column is completely blank. I've tried all sorts of things, including starting with a partial day (starting at midnight), and then extending it (pulling down) to include the 11PM block. No matter what I try, it will not keep the entry. The root cause seems to be the inclusion of the 11PM block. As soon as Saturday 11PM block is there, whatever segment it is part of is wiped out. I suspect it has something to do with the fact that when you move a block down towards the bottom of a given day, whatever 'goes off' the bottom ends up at the top of the next day. This seems to work, except for Saturday.
I would gladly give up the ability to push a block into the next day if it meant I could get all day Saturday to work.
I'm running 3.0.0.4.266.23 (Merlin build). Pretty sure the same problem was there when I was running the Assus firmware before that ( a few releases earlier).
