scribe and uiscribe seem to be working as intended, but I am curious about
1. why the configuration is reloaded twice per hour at xx:57 and then 3 minutes later at xy:00
2. why the default config is looking for the missing file /var/lib/logrotate.status
If it is relevant, the consolidated syslog-ng-complete.conf is
Dec 6 12:57:00 RT-AX88U-5050 syslog-ng[20915]: Follow-mode file source not found, deferring open; filename='/var/lib/logrotate.status'
Dec 6 12:57:00 RT-AX88U-5050 syslog-ng[20915]: Configuration reload request received, reloading configuration;
Dec 6 12:57:00 RT-AX88U-5050 syslog-ng[20915]: Configuration reload finished;
Dec 6 13:00:00 RT-AX88U-5050 syslog-ng[20915]: Follow-mode file source not found, deferring open; filename='/var/lib/logrotate.status'
Dec 6 13:00:00 RT-AX88U-5050 syslog-ng[20915]: Configuration reload request received, reloading configuration;
Dec 6 13:00:00 RT-AX88U-5050 syslog-ng[20915]: Configuration reload finished;
# syslog-ng.conf customized for scribe on Asuswrt-Merlin firmware
# compare to /opt/share/syslog-ng/examples/syslog-ng.conf-opkg for differences from Entware distribution
# syslog-ng documentation: https://www.syslog-ng.com/technical-documents/doc/syslog-ng-open-source-edition/3.29/administration-guide
# Release notes: https://github.com/syslog-ng/syslog-ng/releases
@version: 3.29
#@include "scl.conf" # uncomment this line to for additional functionality, see syslog-ng documentation
@include "/opt/etc/syslog-ng.d/" # Put any customization files in this directory
# don't log empty messages from kernel
filter f_blank {
program("kernel") and
message("^ *$");
log {
source(src);
filter(f_blank);
flags(final);
#eof
# log cake-qos change to /opt/var/log/cake.log only
destination d_cake {
file("/opt/var/log/cake.log");
filter f_cake {
program("CakeQOS-Merlin") or
message ("Cpuidle Host Clock");
log {
source(src);
filter(f_cake);
destination(d_cake);
flags(final);
#eof
# log all diversion and uiDivStats logs to diversion.log
destination d_diversion {
file("/opt/var/log/diversion.log");
filter f_diversion {
program("uiDivStats") or
program("Diversion");
log {
source(src);
filter(f_diversion);
destination(d_diversion);
flags(final);
#eof
# log ethernet change to /opt/var/log/ethernet.log only
destination d_ethernet {
file("/opt/var/log/ethernet.log");
filter f_kernel {
program("kernel");
filter f_ethernet {
message("eth1") or
message("eth2") or
message("eth3") or
message("eth4") or
message("eth5") or
message("eth6") or
message("eth7") or
message("eth8") or
message("br0:");
log {
source(src);
filter(f_kernel);
filter(f_ethernet);
destination(d_ethernet);
flags(final);
#eof
# log hostapd change to /opt/var/log/hostapd.log only
destination d_hostapd {
file("/opt/var/log/hostapd.log");
filter f_hostapd {
program("hostapd") or
program("roamast") or
message ("CFG80211-ERROR");
log {
source(src);
filter(f_hostapd);
destination(d_hostapd);
flags(final);
#eof
# gather logrotate logs together for unified log
destination d_logrotate {
file("/opt/var/log/logrotate.log");
source s_lr_status {
file("/var/lib/logrotate.status" program-override("logrotate") flags(no-parse));
source s_lr_daily {
file("/opt/tmp/logrotate.daily" program-override("logrotate") flags(no-parse));
log {
source(s_lr_status);
source(s_lr_daily);
destination(d_logrotate);
flags(final);
#eof
# log all openvpn server and client logs into one file - /opt/var/log/openvpn.log and stop processing openvpn logs
destination d_openvpn {
file("/opt/var/log/openvpn.log");
filter f_openvpn {
program("ovpn-server1") or
program("ovpn-server2") or
program("ovpn-client1") or
program("ovpn-client2") or
program("ovpn-client3") or
program("ovpn-client4") or
program("ovpn-client5") or
program("openvpn-routing");
log {
source(src);
filter(f_openvpn);
destination(d_openvpn);
flags(final);
#eof
# log all pixelserv-tls logs to /opt/var/log/pixelserv.log and stop processing pixelserv-tls logs
destination d_pixelserv {
file("/opt/var/log/pixelserv.log");
filter f_pixelserv {
program("pixelserv-tls");
log {
source(src);
filter(f_pixelserv);
destination(d_pixelserv);
flags(final);
#eof
# this MUST BE the file configured in Skynet as the syslog.log location
# DO NOT use /tmp/syslog.log or /opt/var/log/messages here!
destination d_skynet {
file("/opt/var/log/skynet-0.log");
# logs everything from Skynet to /opt/var/log/skynet-0.log
filter f_skynet {
program("Skynet") or
message("BLOCKED -") or
message("DROP IN=");
# final flag stops processing of messages matching the f_skynet filter
log {
source(src);
filter(f_skynet);
destination(d_skynet);
flags(final);
#eof
# put spdMerlin's speed test results into /opt/var/log/spdMerlin.log
destination d_spdmerlin {
file("/opt/var/log/spdmerlin.log");
filter f_spdmerlin {
program("spdMerlin");
log {
source(src);
filter(f_spdmerlin);
destination(d_spdmerlin);
flags(final);
#eof
# put syslog-ng's logging stats into /opt/var/log/syslog-ng.log
destination d_syslogng {
file("/opt/var/log/syslog-ng.log");
filter f_syslogng {
program("syslog-ng")
log {
source(src);
filter(f_syslogng);
destination(d_syslogng);
flags(final);
#eof
# log all unbound logs to /opt/var/log/unbound.log and stop processing unbound logs
destination d_unbound {
file("/opt/var/log/unbound.log");
filter f_unbound {
program("unbound") or
program("gen_adblock.sh");
log {
source(src);
filter(f_unbound);
destination(d_unbound);
flags(final);
#eof
# put wlceventd Assoc/ReAssoc/Disassoc messages into /opt/var/log/wlceventd.log
destination d_wlceventd {
file("/opt/var/log/wlceventd.log");
filter f_wlceventd {
( ( program("WLCEVENTD") or
program("wlceventd") ) and
( message("ssoc") or
message("uth") ) ) or
( program("syslog") and
message("wlceventd") );
log {
source(src);
filter(f_wlceventd);
destination(d_wlceventd);
flags(final);
#eof
options {
chain_hostnames(no); # Enable or disable the chained hostname format.
create_dirs(yes);
keep_hostname(yes); # Enable or disable hostname rewriting.
log_fifo_size(256); # The number of messages that the output queue can store.
log_msg_size(16384); # Maximum length of a message in bytes.
stats_freq(21600); # The period between two STATS messages sent by syslog-ng, containing statistics about dropped logs in seconds; 0 disables. (21,600 seconds = 6 hours)
flush_lines(0); # How many lines are flushed to a destination at a time.
use_fqdn(no); # Add Fully Qualified Domain Name instead of short hostname.
# syslog-ng gets messages from the system, kernel, and syslog-ng (internal)
# DO NOT use system() source; causes issues on HND routers
# so_rcvbuf = maximum number of messages per second * 1024
source src {
unix-dgram("/dev/log" so_rcvbuf(65536) flags(syslog-protocol));
file("/proc/kmsg" program_override("kernel") flags(kernel));
internal();
# udp(ip(192.168.x.y) port(514)); # uncomment this line to pass all network messages through syslog-ng filters
# if you only want to pass network messages through some syslog-ng filters, uncomment the source line below
# then add "soource(net);" to the log statement in any filter you want to pass network messages through
#source net { udp(ip(192.168.x.y) port(514)); };
# set the filename for the default log file - anything not filtered out will end up here
destination messages { file("/opt/var/log/messages"); };
# to send log messages to the local network, uncomment the destination line below
# then add "destination(log_server);" to the log statement in any filter you want to pass network messages through
#destination log_server { udp("192.168.x.y" port(514)); };
log {
source(src);
# source(net); # uncomment this and "source net" function above to get udp log messages from local network
destination(messages);
# destination(log_server); # uncomment this and "destination log_server" function above to send udp log messages to local network
