script VPN Client goes down
schranzc
Hello,
I know the script "openvpn-event" which is called whenever the OpenVPN-Client connects (or VPN-Server connects or go down) - but is there a way to run a script if OpenVPN-Client goes down?
Thank you so much!
updown.sh is called on --up and --down, and in turns it also calls openvpn-event.
There are other script hooks in OpenVPN, check the man page in case --down doesn't get called on a pure disconnect (rather than the client being manually stopped).
I don't know what I should do :) Where should I add the file "updown.sh"? In "/jffs/scripts/"? - doesn't work :(
updown.sh is what the firmware uses internally, you cannot replace it. That script will call openvpn-event, which is the one you can create to put your own code in it.
Hello,
Thank you so much!
https://tunnelblick.net/cUsingScripts.html
route-up is executed after connection authentication, either immediately after, or some number of seconds after as defined by the --route-delay option.
route-pre-down is executed right before the routes are removed.
down is executed after TCP/UDP and TUN/TAP close.
you have sample script /jffs/scripts/vpn-route-1.sh check link below, adjust it to your need
http://www.snbforums.com/threads/de...-usual-with-asuswrt-merlin.31415/#post-253228
