Scripting/Automating Port Forwarding?
reub
I'd like to programmatically enable and disable port forwarding on my router (use case below).
It should be straightforward enough to write the IPTables rules, but I'm not sure what event (if any) I can use as a trigger. Is updating the nat-start script and rebooting the router the best option here or are there other (less kludgy) approaches I might take?
Use Case: As part of the Let's Encrypt project, SSL certificate issuance and renewal is automated but requires that the requesting domain be reachable. My domain typically resides behind my router and is not reachable from the public internet for a domain validation challenge. Since certificates are relatively short-lived, renewal automation is encouraged. So, I'd like to be able to programmatically open and close the relevant ports in Merlin as part of my renewal scripts.
... I think it has been asked several times that this feature is available via the GUI itself and indeed, that would be a very nice and handy feature (available in Tomato) ....
GS
What about a cron job that runs an iptables script in jffs?
@Schuby Good thought, that would allow it to be open at certain intervals perhaps, but not as part of a script and thus not easily orchestrated into a larger effort.
@GSpock thank you, good to know.
Since we're on this subject and I've searched for the last day or so for it, is there a way via command line (ssh of course) to reload the firewall once you make a chance, say to nat-start? I'd rather not have to reboot every time as it seems I have an issue with the ISP constantly issuing me a new IP when I do (like the MAC address of the device attached to the modem is changing, although I have it cloned in settings".
Thanks for any help.
