Scripts from /jffs/scripts not running
spl
Hi.
I have modified startup scripts from github
admin@RT-N66U:/tmp/home/root# ls -la /jffs/scripts
drwxrwxrwx    2 admin    root             0 Oct  1 18:03 .
drwxr-xr-x    5 admin    root             0 Jan  1  1970 ..
-r-xr-xr-x    1 admin    root           234 Oct  1 18:44 firewall-start.sh
-r-xr-xr-x    1 admin    root            41 Oct  1 18:56 init-start.sh
-r-xr-xr-x    1 admin    root           234 Oct  1 16:25 nat-start.sh
-r-xr-xr-x    1 admin    root            50 Sep 30 21:51 post-mount.sh
-r-xr-xr-x    1 admin    root           209 Oct  1 18:40 pre-mount.sh
-r-xr-xr-x    1 admin    root           234 Oct  1 18:08 services-start.sh
-r-xr-xr-x    1 admin    root           458 Sep 30 21:52 services-stop.sh
-r-xr-xr-x    1 admin    root           234 Oct  1 16:24 unmount.sh
-r-xr-xr-x    1 admin    root            90 Sep 30 21:51 wan-start.sh
for exampe i show services-start.sh
admin@RT-N66U:/tmp/home/root# cat /jffs/scripts/services-start.sh
#!/bin/sh
echo 1.txt >> '/mnt/sda1/1.txt';
rm -R /mnt/sda1/test/;
echo 2.txt >> '/mnt/sda1/2.txt';
mkdir /mnt/sda1/test/;
echo 3.txt >> '/mnt/sda1/3.txt'
chmod -R 755 /mnt/sda1/test/;
echo 4.txt >> '/mnt/sda1/4.txt';
nvram jffs settings
admin@RT-N66U:/tmp/home/root# nvram show | grep jffs
jffs2_on=1
size: 44244 bytes (21292 left)
jffs2_exec=1
jffs2_size=6291456
jffs2_format=0
If i right understand after boot and mount partitions on my sda1 i see 4 files and 1 folder.
But it not happening.
What i do wrong?
Thanks for advice.
Recheck your filenames. There should not be any ".sh" in their names.
Thanks a lot.
It works.
I miss this little thing
About this error's:
Jan  1 02:00:11 hotplug[385]: USB /dev/sda1(ext4) failed to mount at the first try!
Jan  1 02:00:11 kernel: kjournald starting.  Commit interval 5 seconds
Jan  1 02:00:11 kernel: EXT3 FS on sda1, internal journal
Jan  1 02:00:11 kernel: EXT3-fs: mounted filesystem with ordered data mode.
Jan  1 02:00:11 hotplug[385]: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/sda1
i need to cteate another topic?
It's on my flash and on external hdd's
I try to format my devices into ext2, ext3, ntfs, vfat from windows(acronis) and from router
Only vfat FS dosen't have this error on startup
SD cards 8 and 32 Gb's
HDD's 250Gb and 1TB
Rack is Welland ME-280J
Ignore this error. It's just a minor issue where the firmware tries to mount ext2/ext3 volumes as ext4 first. It will still mount properly.
