Scripts help please
tmcb82
Hi I am trying to write a script that runs a command to push my usb into another mode but it doesn't seem to be running at boot... I'm not sure what I am doing wrong?
#!/bin/sh
usb_modeswitch -v 0x1410 -p 0x9020 -u 2
This is the script. I put it in /jffs/scripts and made it executable.
/jffs/scripts/u620lmodem startup # u620lmodem
I then added the above to the start-services file in the scripts folder.
When I run the usb_modeswitch command from ssh it works perfect but only lasts until the router is rebooted, so I was trying make it automatically apply at boot to make my life a bit easier.
Any ideas would be immensely helpful! Thank you in advance!
Is it a typo in your post? The file is /jffs/scripts/services-start, not start-services.
services-start must also include #!/bin/sh and be executable. You can just put the usb command directly in services-start if you want, without the u620lmodem script.
Ohh sorry, yes it was a typo I used services-start. I actually was able to append it below another script that uses that.
Does the other script in services-start run OK on boot?
It does! Which is why I’m scratching my head. Could it be executing too early since it controls a USB modem? Perhaps moving it to post-mount would be better?
Thanks for the help btw
I figured it out! It was running but before the modem incorrectly mounts as a usb drive. So I added “Sleep 3m” before the command to make it wait 3 minutes before running and now it works perfectly.
So is there a better place to put it to avoid a 3 minute delay? Does post-mount trigger for a USB modem?
I kept this in services-start:
/jffs/scripts/modem.sh startup # Switch U620L to modem
Then this script:
#!/bin/sh
sleep 3m
It works great now. My primary cable internet now fails over to this Verizon Novatel U620L USB modem and back when the primary internet is restored. I also installed "usbutils" from entware.
I'm not sure why you're passing "startup" as a parameter to your script as the script doesn't use it.:confused:
It sounds like it might not be needed. I saw it in other scripts and copied it. I’m not a programmer, so I‘m just learning as I go. If I made other mistakes please point them out. I would appreciate it!
