Seeking advice. APT / MitM
Atlas Prime
Hello SNB,
I'll try to keep this brief.
I was hacked and believe threat actors dropped an APT. Notepad had been hijacked, perhaps via modified .dll . I discovered the breach when notepad had been left open with files open that I hadn't created. One file was a string of Korean (or other Asian language) that was actively being modified as I watched (new characters being added). Another file was a list of all of my crypto transactions.
Needless to say av software was useless. Log indicating new folder creation attempts in protected exe that were being spammed and blocked, detected MitM and other entries. Entire system compromised from router to endpoints.
Used diskpart cleanall.
Fresh os install.
Persistent dir/files upon examination.
Shutdown and unplug entire system.
Got a "new" router.
Got a new phone.
Set up router and hardened it.
Purchased Parted Magic and burned iso to flash using etchdroid.
Booted pc using flash drive.
Secure erase fails(perhaps due to tpm or secure boot? Didn't evaluate decided to use nwipe).
Nwipe reports successful.
After nwipe noticed puid tool showing nbd's. Also i thought nwipe would remove partitions.
I'm not familiar with nbd's , but researched them and to my understanding are used in distributed storage and basically give remote access.
I'm not sure how to proceed in securing this pc.
If anyone could advise it would be appreciated.
you may have to throw it away. Unless you want to spend the $ for a pro to figure it out.
Which distribution of Linux this is running?
Because the screenshot came from a Linux Desktop.
You or a group package you installed installed nbd-server or ndb-client.
of course you can remove them with:
sudo apt-get purge nbd-server
sudo apt-get purge nbd-client
There are plenty of tutorials online for wiping a drive with Linux.
You boot with a linux install disk and:
ctrl-alt-t (open terminal)
sudo dd if=/dev/zero of=/dev/(your drive block device(sda or nvme0n1) status=progress
Ty for reply.
Since I'm unfamiliar with Linux and parted magic , and also didn't know about nbd's, I wasn't sure what to do.
Turns out pmagic is loading the nbd's.
Also nwipe did clear everything including partitions.
Now all that's left is to verify that every single block has been cleared.
Ty for reply.
Interesting that gparted does that. I rarely use it.
