I'm running Asuswrt-Merlin v380.68_4 on my Asus RT-AC87U. I just successfully set up Pi-hole (a DNS server) on a Raspberry Pi 3 and pointed my router to it via "Advanced Settings/LAN/DHCP Server/DNS and WINS Server Setting/DNS Server 1". It all works great with one caveat: some clients aren't hitting the LAN DNS server. I noticed the clients in question all have static IPs assigned according to the network map. However, I've only defined one static IP and that's the Pi-hole device. As far as I'm aware, the only place to set static IPs is under LAN/DCHP Server. The clients with static IPs seem to be arbitrary and come from different interfaces (both Ethernet and WiFi)
I should also note that I've run Asuswrt-Merlin for a long time. Could this be a bug related to multiple upgrades over time? Do I need to completely reset my router? Is there an easier solution? Is there another setting I've missed?
Thanks in advance for any help you could provide.
