segmentation fault on ntp
Kevin K
Need help with ntp segmentation faults.
  • GUI reports: "Reminder: The system time has not been synchronized with an NTP server."
  • syslog.log contains many: "reboot_scheduler: [timecheck] NTP sync error"
  • Running "ntp -w -p pool.ntp.org" reports: "Segmentation fault"
  • Running "ntp -w -p 192.81.135.252" reports "ntp: reply from 192.81.135.252..."
  • Running "ntp -w -p go.boom.now" reports "Segmentation fault"
So clearly, ntp doesn't like something about my DNS.
"nslookup pool.ntp.org" reports
Server:    8.8.8.8
Address 1: 8.8.8.8 dns.google
Address 1: 45.55.58.103 time.walb.tech
Address 2: 204.2.134.163 pacific.latt.net
Address 3: 129.250.35.250 x.ns.gin.ntt.net
Address 4: 50.18.44.198 smtp.brandonenright.net
or, if I enable "Wan: Use local caching DNS server as system resolver (default: No)" it reports
Server:    127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 129.250.35.251 y.ns.gin.ntt.net
Address 2: 108.62.122.57 ntp2.radio-sunshine.org
Address 3: 99.104.170.138 99-104-170-138.lightspeed.lsvlky.sbcglobal.net
Address 4: 184.105.182.7 ntp3.junkemailfilter.com
but either way, I get segmentation faults when I run "ntp -w -p pool.ntp.org".
If I configure the GUI with an IP address for a time server, it synchs. Suggestions?
Server:    8.8.8.8
Server:    127.0.0.1
I used IP for a long while, very reliable, unlike my experience using domain names.
Now using Chrony via ntpMerlin, works superbly.
Fair question.
AC68U and AC1900
Version 384.19
(And I just added those to my signature but, sadly, I haven't figured out how to make my signature show up here.)
Same problem with my router too, Merlin firmware version:386.1, Asus RT-AC88U.
Running "ntp -w -p pool.ntp.org" returns "Segmentation fault"
Running "ntp -w -p 162.159.200.123" returns "ntp: reply from 162.159.200.123: offset...""
Any sustainable solutions other than hardcoding IP address in GUI? ;)
working fine here
octopus@RT-AX86U-EA08:/tmp/home/root# ntp -w -p pool.ntp.org
ntp: reply from 147.78.229.141: offset:+0.005022 delay:0.003862 status:0x24 strat:2 refid:0x94ca3ac2 rootdelay:0.000687 reach:0x01
ntp: reply from 147.78.229.141: offset:+0.005001 delay:0.003983 status:0x24 strat:2 refid:0x94ca3ac2 rootdelay:0.000687 reach:0x03
