Xentrk
Part of the Furniture
This project has been superseded by the x3mRouting ~ Selective Routing for Asuswrt-Merlin Firmware project.
The purpose of this project is to selectively route Netflix traffic to the WAN interface, or one of the five OpenVPN clients, on Asuswrt-Merlin firmware, using the method espoused by @Martineau on snbforums.com.
The routing of Netflix traffic is a frequent topic on this and other forums. Since January 2016, Netflix blocks VPN providers. This project was originally developed to bypass the OpenVPN client for Netflix traffic and route it to the WAN interface. The scripts now provide the ability to route Netflix traffic to an OpenVPN Client if desired. If you want a VPN provider who can circumvent the Netflix VPN ban, see my blog post Why I use Torguard as my VPN Provider to learn more.
There are two selective routing scripts used in this project. Each one uses a different method to collect the IPv4 addresses required for selective routing. Both scripts use the features of IPSET to collect IPv4 addresses in IPSET lists and match against the IPSET lists. Users can select the script that works best for their environment.
IPSET_Netflix.sh collects the IPv4 addresses used by Netflix from https://ipinfo.io using the Autonomous System Number (ASN) assigned to Netflix. Amazon AWS supplies the list of IPv4 addresses in the json file at https://ip-ranges.amazonaws.com/ip-ranges.json
Only the Amazon AWS US Regions are extracted from ip-ranges.json. As a result, the script will also route all Amazon AWS traffic bound for the US, including Amazon Prime traffic, to the WAN interface.
IPSET_Netflix_Domains.sh uses the IPSET feature built into dnsmasq to dynamically generate the IPv4 address used by Netflix and Amazon AWS dynamically. This approach can be useful when your ISP is using the Netflix Open Connect Network.
Project documentation and install instructions are available on github.com. Earlier versions of the scripts posted throughout this thread may no longer work.
