Need help on setting up the following:
> Create two (2) networks (no more than 8 computers on each) each with access to the Internet but not to each other.
> Create a static route to a Network printer for use by both Networks.
Build redundancy below the ISP (Modem level) > Multiple routers and / or switches such that any one device failing does not interrupt the network.
What would you recommend keeping the hardware to a minimum? All the hardware will be new as the equipment is old and starting to fail.
(And, one of the routers that failed was a sub-router with the WAN port looped back to the LAN port on the router, why?)
I searched on the Internet and couldn't find any links that helped much. If you know some that would be wonderful too!
Thanks for the help.
