bigfatal
I have a 200Mb fibre connection (Virgin - UK). This runs to the Virgin hub which is configured in modem only mode
I then output from this into a wall socket, along a ~10m cat6, out of another wall socket and into my ASUS RT_AC86U which I use as my router and primary wifi source
I then cable out of this into a nearby TV etc but primarily back along the same router to the modem and into an unmanaged switch. The switch then takes the signal around the house (mostly via Cat6 through the walls but also into a Devolo Homeplug
The rationale behind this over-complication is that the modem is on the edge of the house so moving the router into the lounge which is much more central gives better coverage. (whilst keeping the majority of the cables / kit etc away from areas of the house that are more likely to cause me grief from an unhappy wife who doesnt like mess in the lounge!
However, it obviously makes things complicated. The alternative would be to stick the router next to the modem and avoid all that cabling between them.
So this is a long-winded ay of asking: does it matter if I keep the modem and router apart like this? Is this likely to affect my speeds?
