service-event-end question
omrij
Hi
tried searching before starting this thread and also tried asking chatgpt without success :(
using latest Merlinwrt on GT-AX6000
I have a script which I need to run after every start/restart of wireless and after reboot (but not other events)
this is the template I tried but it didn't work
#!/bin/sh
# Check if the event is start, restart, or reboot
if [ "$1" = "start" ] || [ "$1" = "restart" ]; then
    if [ "$2" = "wireless" ]; then
        logger "Wireless is starting or restarting. Executing custom script..."
        # Place your custom commands here
        # Example: restart a service, configure settings, etc.
        # /path/to/your/custom/script.sh
    fi
elif [ "$1" = "reboot" ]; then
    logger "System is rebooting. Executing custom reboot script..."
    # Place your custom reboot-related commands here
    # /path/to/your/custom/reboot_script.sh
fi
any help would be appreciated
Ran into similar problem quite some time ago. You would think the event model was thorough and complete, but I ran across several times when events simply weren't triggered for some reason. I ended up actually taking the template and writing a message to the log each time it was called so I could tell exactly when it was called, and for what service. It was then I realized you can't just assume it will work for all services, all the time.
Annoying, but that's just the way it is. I ended up using other events as a workaround.
Based on the asuswrt-merlin's official documentation, I'm not sure if I fully understand it correctly. You might want to give it a try yourself.
Capturing Wireless Service Restart Events (service-event and service-event-end)
You can create two scripts to handle the events before and after the wireless service starts or stops. These scripts will be triggered when events like start, stop, or restart occur for the wireless service.
Example for service-event:​
This script will be executed before the wireless service is restarted, stopped, or started.
#!/bin/sh
EVENT=$1  # Event type: start, stop, restart
TARGET=$2  # Target service: wireless, httpd, etc.
# Check if the target is wireless
if [ "$TARGET" = "wireless" ]; then
    echo "custom commands here"
fi
Example for service-event-end:​
This script will be executed after the wireless service has completed starting, stopping, or restarting.
#!/bin/sh
fi
I've observed that other scripts also retrieve the status in a similar way.
#!/bin/sh
if [ "$1" = "start" ] && [ "$2" = "SkynetStats" ]; then sh /jffs/scripts/firewall debug genstats; fi # Skynet
/jffs/scripts/scribe service_event "$@" & # added by scribe
if echo "$2" | /bin/grep -q "uiScribe"; then { /jffs/scripts/uiScribe service_event "$@" & }; fi # uiScribe
if echo "$2" | /bin/grep -q "connmon"; then { /jffs/scripts/connmon service_event "$@" & }; fi # connmon
/jffs/scripts/dn-vnstat service_event "$@" & # dn-vnstat
if echo "$2" | /bin/grep -q "ntpmerlin"; then { /jffs/scripts/ntpmerlin service_event "$@" & }; fi # ntpMerlin
if echo "$2" | /bin/grep -q "scmerlin"; then { /jffs/scripts/scmerlin service_event "$@" & }; fi # scMerlin
/jffs/addons/unbound/unbound_stats.sh generate "$1" "$2" & # Unbound_Stats.sh
[ "$2" = diversion ] && /opt/share/diversion/webui/process.div "$1" & # Added by Diversion
if echo "$2" | /bin/grep -q "uiDivStats"; then { /jffs/scripts/uiDivStats service_event "$@" & }; fi # uiDivStats
I'm not sure if the target service name is 'wireless', 'wlceventd', or something else.
