Set PLEX to highest priority on AC68U
b0gd4n
Hey guys,
I currently have the QoS disabled, but I wanted to set PLEX to highest priority on AC68U.
Can someone please let me know how do I do this?
Thanks in advance!
Hey guys,
Thanks in advance!
You cant without QoS, with QoS disabled everything is highest priority.
Set your upload and download to what ever your being provided.
Go to configuration/rules.
Under service name type in what you want and select the device under source ip/mac.
under priority set the device to to desired level and then click the plus sign.
Repeat for all the devices setting the ones you want to stream to and from as the highest. (pc with plex server and device playing plex)
Set the others to something below highest.
This way the plex devices get priority over the bandwidth.
Once down click apply at the bottom
Under configuration/prorites you can set what the proties get in terms of bandwidth but its only nesssery if you plan on really fine tuning it.
