Set PPPOE reconnect timer? (or reboot timer)
ipumuk
thanks a lot for your great custom firmware, Merlin!
I have an ISP that disconnects me every 24 hours. it sucks when i am being disconnected during a skype or gaming session.
is there a way to set a specific time when the router should reconnect the PPPOE connection? (like reconnect PPPOE every day at 5am?)
if that is not possible, is there a way to automatically reboot the router at a specific time?
thanks for your help in advance.
After enabling /jffs open a terminal like putty and input this commands
[B][SIZE="3"]echo "#!/bin/sh" >/jffs/scripts/init-start
echo "cru a ScheduledWanRestart \"0 5 * * * service restart_wan\"" >>/jffs/scripts/init-start[/SIZE][/B]
[B][SIZE="3"]chmod a+rx /jffs/scripts/init-start[/SIZE][/B]
[B][SIZE="3"]reboot[/SIZE][/B]
Verify if is added to cron job list
should output
0 5 * * * service restart_wan #ScheduledWanRestart#
Thanks a lot for the fast and great help!
It seems that it worked. I got the following feedback:
admin@RT-N66U:/tmp/home/root# cru l
I do not understand the whole log but it worked i guess ;)
Thx again, TeHashX.
Jan 11 05:00:01 crond[323]: crond: USER admin pid 13525 cmd service restart_wan
Jan 11 05:00:01 rc_service: service 13526:notify_rc restart_wan
Jan 11 05:00:01 pppd[374]: Hangup (SIGHUP)
Jan 11 05:00:01 pppd[374]: Connect time 332.7 minutes.
Jan 11 05:00:01 pppd[374]: Sent 634372987 bytes, received 1920240512 bytes.
Jan 11 05:00:01 dnsmasq[414]: read /etc/hosts - 5 addresses
Jan 11 05:00:01 dnsmasq[414]: read /etc/hosts.dnsmasq - 2 addresses
Jan 11 05:00:01 dnsmasq-dhcp[414]: read /etc/ethers - 2 addresses
Jan 11 05:00:02 pppd[374]: Terminating on signal 15
Jan 11 05:00:02 pppd[374]: Connection terminated.
Jan 11 05:00:02 pppd[374]: Sent PADT
Jan 11 05:00:02 dnsmasq[414]: using nameserver 62.xxxx
Jan 11 05:00:02 dnsmasq[414]: read /etc/hosts - 5 addresses
Jan 11 05:00:02 dnsmasq[414]: read /etc/hosts.dnsmasq - 2 addresses
Jan 11 05:00:02 dnsmasq-dhcp[414]: read /etc/ethers - 2 addresses
Jan 11 05:00:02 dnsmasq[414]: ignoring nameserver 192.168.1.1 - local interface
Jan 11 05:00:02 pppd[374]: Exit.
Jan 11 05:00:02 stop_wan(): perform DHCP release
Jan 11 05:00:02 kernel: br0: port 1(vlan1) entering disabled state
Jan 11 05:00:02 kernel: vlan1: dev_set_promiscuity(master, 1)
Jan 11 05:00:02 kernel: br0: port 1(vlan1) entering listening state
Jan 11 05:00:02 kernel: br0: port 1(vlan1) entering learning state
Jan 11 05:00:02 kernel: br0: topology change detected, propagating
Jan 11 05:00:02 kernel: br0: port 1(vlan1) entering forwarding state
Jan 11 05:00:04 WAN Connection: Fail to connect with some issues.
Jan 11 05:00:04 stop_nat_rules: apply the redirect_rules!
Jan 11 05:00:04 dnsmasq[414]: exiting on receipt of SIGTERM
Jan 11 05:00:04 dnsmasq[13563]: started, version 2.67 cachesize 1500
Jan 11 05:00:04 dnsmasq[13563]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan 11 05:00:04 dnsmasq[13563]: warning: interface ppp1* does not currently exist
Jan 11 05:00:04 dnsmasq[13563]: asynchronous logging enabled, queue limit is 5 messages
Jan 11 05:00:04 dnsmasq-dhcp[13563]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Jan 11 05:00:04 dnsmasq[13563]: read /etc/hosts - 5 addresses
Jan 11 05:00:04 dnsmasq[13563]: read /etc/hosts.dnsmasq - 2 addresses
Jan 11 05:00:04 dnsmasq-dhcp[13563]: read /etc/ethers - 2 addresses
Jan 11 05:00:04 dnsmasq[13563]: ignoring nameserver 192.168.1.1 - local interface
Jan 11 05:00:04 pppd[13566]: Plugin rp-pppoe.so loaded.
Jan 11 05:00:04 pppd[13566]: RP-PPPoE plugin version 3.11 compiled against pppd 2.4.5
Jan 11 05:00:04 pppd[13567]: pppd 2.4.5 started by admin, uid 0
Jan 11 05:00:04 pppd[13567]: PPP session is 21265 (0x5311)
Jan 11 05:00:04 pppd[13567]: Connected to fc:48:ef:29:8a:eb via interface eth0
Jan 11 05:00:04 pppd[13567]: Using interface ppp0
Jan 11 05:00:04 pppd[13567]: Connect: ppp0 <--> eth0
Jan 11 05:00:05 pppd[13567]: Remote message: Pedo mellon a minno : xxxx atm 0/14/0/28:1.32 - <unknown>
Jan 11 05:00:05 pppd[13567]: PAP authentication succeeded
Jan 11 05:00:05 pppd[13567]: peer from calling number FC:48:EF:29:8A:EB authorized
Jan 11 05:00:05 miniupnpd[494]: Failed to get IP for interface ppp0
Jan 11 05:00:05 miniupnpd[494]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Jan 11 05:00:05 pppd[13567]: local  IP address 77.xxxx
Jan 11 05:00:05 pppd[13567]: remote IP address 213.xxxx
Jan 11 05:00:05 pppd[13567]: primary   DNS address 62.xxxx
Jan 11 05:00:05 pppd[13567]: secondary DNS address 62.xxxx
Jan 11 05:00:05 dnsmasq[13563]: read /etc/hosts - 5 addresses
Jan 11 05:00:05 dnsmasq[13563]: read /etc/hosts.dnsmasq - 2 addresses
Jan 11 05:00:05 dnsmasq-dhcp[13563]: read /etc/ethers - 2 addresses
Jan 11 05:00:05 dnsmasq[13563]: using nameserver 62.xxxx
Jan 11 05:00:05 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Jan 11 05:00:05 dnsmasq[13563]: exiting on receipt of SIGTERM
Jan 11 05:00:05 dnsmasq[13590]: started, version 2.67 cachesize 1500
Jan 11 05:00:05 dnsmasq[13590]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan 11 05:00:05 dnsmasq[13590]: warning: interface ppp1* does not currently exist
Jan 11 05:00:05 dnsmasq[13590]: asynchronous logging enabled, queue limit is 5 messages
Jan 11 05:00:05 dnsmasq-dhcp[13590]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Jan 11 05:00:05 dnsmasq[13590]: read /etc/hosts - 5 addresses
Jan 11 05:00:05 dnsmasq[13590]: read /etc/hosts.dnsmasq - 2 addresses
Jan 11 05:00:05 dnsmasq-dhcp[13590]: read /etc/ethers - 2 addresses
Jan 11 05:00:05 dnsmasq[13590]: using nameserver 62.xxxx
Jan 11 05:00:05 kernel: HTB: quantum of class 10002 is big. Consider r2q change.
Jan 11 05:00:05 kernel: HTB: quantum of class 10060 is big. Consider r2q change.
Jan 11 05:00:05 rc_service: ip-up 13572:notify_rc stop_upnp
Jan 11 05:00:05 rc_service: ip-up 13572:notify_rc start_upnp
Jan 11 05:00:05 miniupnpd[13636]: HTTP listening on port 53026
Jan 11 05:00:05 miniupnpd[13636]: Listening for NAT-PMP traffic on port 5351
Jan 11 05:00:09 WAN Connection: WAN was restored.
Thx again, TeHashX.
Yes, wan was restarted.
Sent from my HTC One using Tapatalk
