jasons6930
Good morning all!!
Apologies if this is in the wrong forum but please move if so.
My set up currently consists of ISP -> Edgemax poe 5 port router, which has 2 lan enabled to avoid s/w bridging. LAN1 is feeding a tp link switch for the wired devices, while LAN2 is set up with 2,3,4 each supplying poe to 3 wifi access points around the house that supply various wifi devices. I purchased the edgerouter specifically for its 48V poe facility so that i could do away with the poe adapters.
However, i now have the issue where the two LANS dont talk to each other, and my printer, internet radios, tv etc which is connected to the tp link switch, i cannot connect wirelessly via mobile phone or laptop etc to the printer etc etc on the wired network.
Is there a simple solution to this?
I would like to set this via the GUI if possible , however, if it necessary to purchase a bigger switch with 48V poe then so be it!
I hope that make sense!
Thanks in advance.
Thanks in advance.
