Settings in the router in a survey before the reset.
HorstG
Hi I have now a FW update aud made ​​the Merlin 43. RTN 66U.
Now, a reset is required.
Then I would have all the settings to adjust!
But what I have set everything?
Is there a possibility of any changes in a list or allow Overview Show? This readjustment is easier.
hopefully this translates ok for you. the easiest way to preserve your settings will be to take screenshots and re-enter them yourself. however, if the previous firmware is only slightly older than the new firmware, you probably will not need to reset. usually, you only need to reset if you upgrade to a firmware with a different wireless driver version. if you are upgrading from official firmware to merlin firmware, you will need to reset as the merlin firmware uses a special wireless driver that came from Asus, but can't be used in the official firmware.
