Hello,
I have the AC-3100 with latest stable merlin firmware. Anyone know if you can set a SSID over the 5ghz band to only be on the guest network?
I have Chromecasts, Roku, and Google Nest items in my house and I would like to move them all to the guest network over 5ghz to keep them from gaining access to the internal LAN.
I have a RT-N66U used as a Wireless Extender on one end of the house and a RP-AC56 as an extender on the other. I would like to use these two extend the 5ghz guest network while using the same SSID on all three devices.
I'm trying to only use 2 SSID's through out the whole network. An internal Lan SSID over the 2.4ghz band and a guest network SSID over the 5ghz band.
Under Wireless - General it does not let me remove the SSID from the Lan side 5ghz band. If I disable this band it also disables the guest side of house.
Any ideas?
Any ideas?
