JoyceBabu
I have an Asus RT N18 router with TomatoUSB installed. The router subnet is 192.168.0.0/24. I have a docker daemon running on a linux client (192.168.0.10). There is a docker network configured on the above client with subnet 10.10.0.0/24. WAN port is connected to a Cable modem in DHCP mode.
I want to allow every client on the 192.168.0.0/24 subnet access to the docker network. So, I have configured the following static route
Destination - 10.10.0.0
Gateway - 192.168.0.10
Subnet - 255.255.255.0
Metric - 0
Interface - LAN
Most of the times this works as expected, and I get the following traceroute output.
But many times, the packets are sent to the WAN port instead of the static route.
Is there anything else that I should do, in addition to creating the static route, for this to always work correctly?
Metric - 0
Interface - LAN
$ traceroute 10.10.0.100
traceroute to 10.10.0.100 (10.10.0.100), 64 hops max, 52 byte packets
1 192.168.0.1 (192.168.0.1) 1.956 ms 0.961 ms 3.210 ms
2 192.168.0.10 (192.168.0.10) 2.907 ms 1.754 ms 1.641 ms
3 10.10.0.100 (10.10.0.100) 4.351 ms 3.363 ms 1.938 ms
1 192.168.0.1 (192.168.0.1) 7.191 ms 1.557 ms *
2 192.168.1.251 (192.168.1.251) 4.378 ms 5.266 ms 2.247 ms
3 117.247.203.1 (117.247.203.1) 2.831 ms 10.618 ms 3.323 ms
4 117.242.216.1 (117.242.216.1) 3.526 ms 2.777 ms 2.068 ms
5 static.ill.218.248.58.134/24.bsnl.in (218.248.58.134) 63.865 ms 123.344 ms 162.384 ms
6 * * *
7 * 10.10.0.100 (10.10.0.100) 1.970 ms 2.725 ms
