Mokume1
Newb here, I'll try to be as accurate and succinct as possible.
I've a pair of ET8 routers which are about 2 years old and 4 AX units which I bought used, they are approximately 4 years old.
I am experiencing connectivity issues via wired backhaul which has been going on for a week now and has been very frustrating, factory resetting all 6 nodes (3X) has not helped at all.
Periodically the web based GUI and Asus app will show both ET8's and 2 of the AX nodes as being connected fine (via ethernet), then randomly lose connection from the router (ET8) randomly, then magically reconnect.
This odd behavior will repeat itself constantly, my setup is as follows:
ISP service via Spectrum cable
Arris cable modem
One of the ET8 nodes acting as the router
TP Link switch feeding 3 nodes (the remaining ET8 and 2 of the AX6's) in daisy chain fashion.
All ethernet cables test OK, continuity wise.
The ET8 nodes firmware is 3.0.0.4.386_49873-g72159cc, while the AC's are 3.0.0.4.388_22068-gf3adbcd
Operation mode is set as wireless router, all nodes are set on auto for backhaul connection priority and preferred wi-fi uplink AP.
Additionally SmartConnect mode is disabled and all 3 broadcast channels are separated
I've even observed the led indicators on the switch, with no change in their status as the nodes mysteriously disconnect/reconnect.
This is driving me to drink (more) behavior started a week ago, it performed flawlessly prior, could it be attributed to an automatic firmware update? (I've since discovered that this is an unwise setting).
Can anyone please help? My liver will thank you for it...lol
Arris cable modem
