Shell doesn't get local time? Is this new?
vibroverbus
Not sure if this is a new thing or not, I think it is, but just noticed my shell sessions were in UTC. No TZ env variable being exported. I added that to jffs/configs/profile.add and seems to work fine now but... is that new? Or did I just never notice?
All other system dates are churning along fine including everything in the system log (unless I was generating an entry from an interactive shell session)...
Just wondering.
Just wondering.
What firmware and router model is this on?
AC3200 & 384.3
Everything else works brilliantly, and as I say, profile.add fixes it right up (gave me opportunity to add a fancier prompt too, like newer DD-WRT releases use...)
AC3200 & 384.3
The date is correct, just the TZ is wrong?
I can't help, I'm more interested what the shell reports vs the actual UI for my scripts for those seldom cases it is not applied to it.
Yep. No TZ was being set in default profile, so it reports a perfectly correct UST. Unfortunately that was being used for log entries so any shell scripts I was running would be stamping syslog entries with 'dates in the future', while all the system log entries looked fine.
