Hi all,
I want to expand the coverage of my wireless network. My router is a d-link DIR-655, which has been working fine for a couple of years now.
I've recently moved to a new house, and in this building, the second floor only gets very poor WiFi reception. So I'm guessing I've got three options now:
1) Buy a new router, I'm thinking about the Asus RT-AC66U. But, from what I've read, a new router, even a more recent model, does not necessarily mean it'll give me more coverage. More likely the opposite even...
2) I don't really like the idea of repeaters, since I've always read they'll half my thoughput. I also have bad experiences with those, but granted, that was several years ago. These products may have improved since then. But, since I've got a Cat6 cable running from my technical room downstairs to my room upstairs anyway, I figure I would just as well buy a real Access Point and put one of those upstairs. Maybe something like the d-link DAP-1360 or DAP-1522. It doesn't really matter if it's only 2.4 Ghz, my router's the same (for now).
3) Buy another router, disable the DHCP server and I've basically also got an access point, right?
I don't really know what the difference is between option 2 and 3. I mean, I know the physical difference, but contrary to what I would have thought, and Access Point is more expensive than another router! So are there advantages into buying a real Access Point and not just a router from which I would 'make' an Access Point. I mean, if I buy something like the Tp Link WR1043nd, and entire new router would cost me something like 35 euro. The D-link DAP-1522 Access Point is almost double that amount. An EnGenious Access Point is easily five times that amount, that's even more expensive than a new Asus RT-AC66U router!
So what's the catch here? Am I missing something obvious?
Thanks for any info you guys can provide! Cheers!
