Should I Upgrade from ASUS RT-AC68U to RT-BE58U?
Arctic Ace
Hey everyone,
As you know, the beloved ASUS RT-AC68U has officially reached its end-of-life status. While it's been a fantastic router for a decade, it's time to consider a more modern solution.
I'm eyeing the ASUS RT-BE58U as a potential replacement. I'm curious if anyone here has made the switch or has any insights into performance difference between these two routers.
Firmware Support:
- How is the firmware support for the RT-BE58U compared to the 68U (e.g., Merlin)?
- How long can we expect ASUS to support the RT-BE58U with firmware updates and security patches?
Mesh Support:
- How well does the RT-BE58U integrate with other Asus mesh nodes? Is it a seamless experience?
AI Protection and Security Features:
- How do the AI Protection and other security features of the RT-BE58U compare to the RT-AC68U? Are there any significant enhancements?
Mobile Tethering:
- Has anyone tried using the RT-BE58U as a mobile hotspot with both iOS and Android devices? Are both supported?
- How does it work?
Any other notable differences or drawbacks?
I'd appreciate any firsthand experiences or expert opinions. Thanks in advance!
Have you searched for that model in the appropriate ASUS subforum ?
Have you read the other countless post asking the same question about support ?
What country are you in ?
As said many times, AiMesh works best with same hardware, same firmware, ethernet backhaul. Sometimes it works acceptably with differences in the above.
