Show what SSID clients is connected to
Alexsus
Hello
Thank you for a superb firmware that makes a grate product even more grate.
But would it be possible for you to ad information in the client status list to show what SSID the client is connected to.
I have currently 2 networks that I use (one 2.4Ghz and one 5Ghz) and then I have a guest network, and it's hard to tell what is connected to what with out having to go in to the wifi log.
/Alex
There is a option that is close already there. Hover the mouse over the wifi icon beside each client. It will show whether on the 2.4 or 5g. That should help some unless you have a lot of guest networks. Maybe not 100% what you are after but should be helpful
The only information that can be obtained from the driver is on which band a client is connected. That information is already available on the Networkmap.
There's no way to determine if a client is connected to a Guest network.
Then how is it possible to isolate guest network communication from the main lan? That assumes that the guest network is only on one band.
Pablo
Pablo
Because the virtual interface can be managed through ebtables. That does not imply that the wireless driver exposes any particular data.
