Shows as "Disconnected?"
AppleBag
Why does this happen?
When I either login to the WebUI, or just switch from some other tab into the "network map" tab, the box at the top first shows the proper info, then switches to "Disconnected", when actually I am not disconnected?
Currently using Merlin version 384.14_2 on RT-AC68U.
I this screengrab it shows the real info being shown first, then switching to the "disconnected" message.
Hi..
Luckily your problem is not new.
Read this: https://www.snbforums.com/threads/internet-status-disconnected.59830
It's a relatively new thread.
Easily described it's due to the fact asus have started to check for a flag in the router cfe.
And it happens if the router is set in a specific mode.
Read about it in the abow link.
Flashing rmerlins 384.14_2 firmware should make that problem go away. ??
Regards
Jonas
Skickat från min SM-G955F via Tapatalk
