As a complete beginner with SSH I am wondering:
1) If one would like to use SSH scripts to make persistent changes to the way Merlin functions, can a user enable SSH in Merlin, run a script, then disable SSH (and even remove the SSH client completely), and have the script still functioning?
Or would the user need to keep SSH enabled in Merlin and keep the SSH client running for as long as they would like the script to remain functioning?
2a) Do SSH scripts alter the firmware or configuration?
2b) If a user makes a mistake with an SSH script and they restore a saved router configuration that was made prior to running the script, will the script then be absent?
3) Is there an SSH client that is recommended over the standard or portableapps version of Putty?
