Site to Site RT-AXE7800 and RT-AX58U
cip_invest
hi
I got a problem, and i dont know why :) . So lets say Site A its under RT-AXE7800 and B its RT-AX58U
A got 192.168.2.0/24
B got 192.168.3.0/24
Firmare
A-> 3.0.0.4.388_22068
B -> 3.0.0.4.388_22237
I want to connect A to B bidirectional , so any PC/equipament under A can acces any PC/equipament under B and viceversa and for this i have used WiregardVPN as advertised in Asus manual
A - wiregard server
B - wiregard client conected in VPN Fusion
The problem its, A can acces equipament under B , but cant acces router B ( 192.168.3.1 ) and from Site B u cant acces nothing in Site A ( 192.168.2.0/24 even the router who its 192.168.2.1 ) , so its no bidirectional . I have tested also using ping application from asus router B ( 192.168.3.1 ) testing all devices from A , its not working . But if u test from router A ( 192.168.2.1 ) all devices from Site B have ping , but the router B ( 192.168.3.1 ) its ping timeout
Also i switched B server A Client , same issue , Site B cant acces Site A
Do you have any ideeas ?
Before RT-AXE7800 i got a GT-AC2900 and site to site was working fine using OpenVpn and some static route on PCs - it stoped working after WireGuard VPN patch , and as GT-AC2900 dosent support WireGuard i was forced to buy a new router RT-AXE7800
Thanks in advance and Best Regards
You need NAT disabled in advanced settings on the client side also check apply to all devices since it's turned off by default.
This is so damn important and i don't understand why their FAQ does not explain this.
