SIXxS aiccu IPv6 Tunnel
Ok, I am able to get aiccu connected on my router and I am able to ping6 to IPv6 addresses successfully from the router, but my clients are unable to pull IPv6 addresses and connect to IPv6 themselves. Any guidance is appreciated.
It is working for me. Here is something from top of my mind.
Installed aiccu using entware, edited config. Set up 6in4.
Make sure hardware acceleration is turned off.
I am not at home, I can help more after I reach home.
Would be interested to know the details of your configuration. I have aiccu running and the router is able to reach IPv6 when I have it set to DHCP-PD. When I switch to 6in4, the router is no longer able to reach IPv6.
In sixxs make sure that Tunnel Type / endpoint is 6in4-heartbeat.
here is my aiccu config file
username, password and tunnel_id should be changed according to your account detail.
# AICCU Configuration
# Login information
username [I]<first line of TIC Password for this tunnel>[/I]
password [I]<TIC Password for this tunnel, password you have setup>[/I]
# Interface names to use
# ipv6_interface is the name of the interface that will be used as a tunnel interface.
# On *BSD the ipv6_interface should be set to gifX (eg gif0) for proto-41 tunnels
# or tunX (eg tun0) for AYIYA tunnels.
ipv6_interface sixxs
# The tunnel_id to use
# (only required when there are multiple tunnels in the list)
tunnel_id [I]<Tunnel Information for xxxxxx, this xxxxxx is tunnel id>[/I]
# Be verbose?
verbose false
# Daemonize?
daemonize true
# Automatic Login and Tunnel activation?
automatic true
# Require TLS?
# When set to true, if TLS is not supported on the server
# the TIC transaction will fail.
# When set to false, it will try a starttls, when that is
# not supported it will continue.
# In any case if AICCU is build with TLS support it will
# try to do a 'starttls' to the TIC server to see if that
# is supported.
requiretls false
here is 6in4 tunnel detail
Connection type- Tunnel 6in4
Server IPv4 Address - pop ipv4 (from sixx tunnel detail page)
Client IPv6 Address - Your IPv6 (from sixx tunnel detail page)
IPv6 Prefix Length - 64
Tunnel MTU - 1480 (I have changed it in Sixx, Tunnel MTU section)
Tunnel TTL - 255
LAN Prefix Length - 64
LAN IPv6 Prefix - subnet prefix in SUBNETS TABLE without /64
IPv6 DNS Server 1 - 2001:470:20::2
Enable Router Advertisement - Enable
Enable DHCPv6 Server - Enable
This is important or ipv6 will not work.
now go in LAN > SWITCH CONTROL > NAT Acceleration should be disabled.
I am using aiccu w/o issues with NAT Acceleration enabled.
I had some timing issues w/ aiccu start. Therefor I delay aiccu start.
Since the release 374.42 "radvd" and "dhcpv6" are no longer started autmatically. I do it manually via start scripts.
Here is my solution:
/jffs/scripts/wan-start:
#!/bin/sh
ifconfig br0 <mylocal IPv6 router address>/64
ip -f inet6 route del default dev eth0
(sleep 60; /jffs/scripts/IPv6Start)&
/jffs/scripts/IPv6Start:
#!/bin/sh
/opt/sbin/aiccu start /opt/etc/aiccu.conf
if [ ! -f /tmp/var/run/radvd.pid ]
then
        cp /jffs/configs/radvd.conf /etc
        radvd -u admin
fi
if [ ! -f /tmp/var/run/dhcp6s.pid ]
then
        cp /jffs/configs/dhcp6s.conf /etc
        dhcp6s br0
fi
sleep 180
if [ ! -f /tmp/var/run/aiccu.pid ]
then
fi
#!/bin/sh
#!/bin/sh
then
        radvd -u admin
fi
then
        dhcp6s br0
fi
sleep 180
then
fi
Thanks for this. In the wan-start script, is <mylocal IPv6 router address> the a) Client IPv6 or b) LAN IPv6 address?
It's the router's address in your LAN. The address is a combination of the subnet prefix you got from sixxs (the /64 prefix you got w/ your tunnel or if you requested a dedicated subnet one subnet out of the /48 prefix) + the EUI-64 identifier of your router's br0 interface (These are the rightmost 64 bit of the "fe80::..." address).
# Login information
# Be verbose?
verbose false
# Daemonize?
daemonize true
automatic true
# Require TLS?
# is supported.
requiretls false
Tunnel TTL - 255
I am in a double NAT situation and therefore unable to use 6in4-heartbeat tunnels. Is this mission critical in this case?
Could anybody help me with this issue? Should I add some script to aiccu package? At this moment there is a binary only.
I remember gw6c/vpnc packages has some shell script to fire up a tunnel.
you don't need aiccu.sh on merlin asuswrt.
put your aiccu.conf in /opt/etc/
create a script something like this one in /jffs/scripts/wan-start and chmod it 755. the sleep 60 is there to give ntp time to set the routers clock because aiccu wont run if the time is not more-or-less synchronized with the server.
#!/bin/sh
/usr/bin/logger -t $(basename $0) "started [$@]"
# Start SIXXS IPV6 tunnel
# wait for ntp to set system time
( sleep 60 ; /opt/sbin/aiccu start /opt/etc/aiccu.conf ) &
/usr/bin/logger -t $(basename $0) "finished [$@]"
I had a problem with the built-in firewall rules after I rebooted to install 376.49_5 (which I didn't have before) and I haven't figured that out yet. I was searching for a solution to that problem when I came across your post. For now I disabled the built-in IPv6 rules and put my own in instead to get IPv6 connectivity for the clients behind the router. You may have to do the same thing.
Small addition here, I also had issues with the IPv6 firewall in the web interface. The reason was that aiccu was configuring a tunnel on virtual interface called sixxs while the web interface was expecting to use interface v6in4 (when set to 6in4 tunnel) or WAN (when using native). I now put the web interface on 6in4 tunnel and changed aiccu to use v6in4 as the ipv6_interface rather than sixxs, and now the IPv6 firewall also works.
