After upgrading to 6.6.6, the log began to be filled with near constant entries like these:
Jan 11 09:22:41 lloyddobler kernel: [BLOCKED - OUTBOUND] IN= OUT=lo SRC=127.0.0.1 DST=127.0.0.1 LEN=267 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=45000 DPT=45032 LEN=247
Jan 11 09:22:41 lloyddobler kernel: [BLOCKED - OUTBOUND] IN= OUT=lo SRC=127.0.0.1 DST=127.0.0.1 LEN=279 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=45000 DPT=45032 LEN=259
Jan 11 09:22:41 lloyddobler kernel: [BLOCKED - OUTBOUND] IN= OUT=lo SRC=127.0.0.1 DST=127.0.0.1 LEN=207 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=45000 DPT=45032 LEN=187
Jan 11 09:22:41 lloyddobler kernel: [BLOCKED - OUTBOUND] IN= OUT=lo SRC=127.0.0.1 DST=127.0.0.1 LEN=118 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=45000 DPT=45032 LEN=98
Jan 11 09:22:41 lloyddobler kernel: [BLOCKED - OUTBOUND] IN= OUT=lo SRC=127.0.0.1 DST=127.0.0.1 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=38000 DPT=38032 LEN=194
Jan 11 09:22:41 lloyddobler kernel: [BLOCKED - OUTBOUND] IN= OUT=lo SRC=127.0.0.1 DST=127.0.0.1 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=45000 DPT=45032 LEN=194
Jan 11 09:22:41 lloyddobler kernel: [BLOCKED - OUTBOUND] IN= OUT=lo SRC=127.0.0.1 DST=127.0.0.1 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=59000 DPT=59032 LEN=194
Jan 11 09:22:42 lloyddobler kernel: [BLOCKED - OUTBOUND] IN= OUT=lo SRC=127.0.0.1 DST=127.0.0.1 LEN=267 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=45000 DPT=45032 LEN=247
Jan 11 09:22:42 lloyddobler kernel: [BLOCKED - OUTBOUND] IN= OUT=lo SRC=127.0.0.1 DST=127.0.0.1 LEN=279 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=45000 DPT=45032 LEN=259
I was unable to get back into the menu for Skynet for several minutes. It hung at the 'splash screen' and the actual menu would not display:
Router Model; RT-AC3200
Skynet Version; v6.6.6 (10/01/2019) (8df04382fad89e26fe611c131d322ceb)
iptables v1.4.15 - (eth0 @ 192.168.0.1)
ipset v6.32, protocol version: 6
FW Version; 384.6_0 (Jul 25 2018) (2.6.36.4brcmarm)
Install Dir; /tmp/mnt/RT-AC3200/skynet (6.7G / 7.4G Space Available)
SWAP File; /tmp/mnt/RT-AC3200/myswap.swp (256.3M)
Boot Args; /jffs/scripts/firewall start skynetloc=/tmp/mnt/RT-AC3200/skynet
Once I was able to get to the menu, I whitelisted localhost (127.0.0.1) for now and the noise stopped. It apparently caused some sort of issue for my wireless devices as they all reconnected after this was resolved (noticed no major issue on wired connections).
I noticed the other discussion and wanted to add that I do not use dnscrypt.
Skynet also said its connectivity check failed when the menu did finally load:
Internet-Connectivity |
[Failed]
