Long time lurker but this is actually my first post.
Thank you for all the hard work creating and maintaining skynet - and the same to merlin and all the other add-ons creators and maintainers. Asuswrt-merlin is the sole reason I keep investing in these equipments.
I have the habit of blocking the ip range for all ips detected by the Two-Way Intrusion Prevention System. This is usually fine as I get a couple attacks per week and I can easily update using the readme method. Last week I had an attack coming from many different ip addresses - mostly from Verizon Business, Charter Communications, Frontier Communications and Optimum Online. These ip's belong to over 30 different ip ranges.
Also, last time I did a full reset to the router I had to spend some time manually adding all the ranges I had previously blocked.
I was wondering if there is a way to import a bulk range of ip ranges, or a file I can edit, to add ip ranges in bulk (each one with it's own comment). As per the read me, I think I can only import a blacklist file.txt but I think it only works for individual ip's and it adds them all with the same comment?
Thank you in advance for your help.
